AlarmForce equipment
Change the batteries in your AlarmForce equipment
Legacy panel
  1. Turn off and disconnect the power for the panel
  2. Remove the panel lid to the battery
  3. Remove the used lead-acid battery by detaching the white clip. Connect the new lead-acid battery using the same white clip
  4. Insert a new 12V Lead Acid battery into the panel. Put the excess wires to the side of the battery into the panel. Put the excess wires to the side of the battery
  5. Re-attach the panel lid
  6. Turn the panel back on
  7. Test whether the replacement is successful by arming and disarming the panel. If the panel no longer says "low system battery," the replacement is successful
  8. Please dispose of the used lead-acid battery by contacting your local battery recycling programs
Learn how to replace the battery of your TELUS Secure Business AlarmForce legacy panel from your phone. Do it yourself by watching the brief video. For more information on managing your TELUS Secure Business, visit
telus.com/en/business/support
Wireless carbon monoxide alarm 80 AF
  1. Remove the CO detector from mounting plate by twisting it counter clockwise to unlock
  2. Open the cover
  3. Insert a new CR123 battery into the device
  4. Close the cover
  5. Twist the CO detector clockwise to lock onto the mounting plate
  6. Please dispose of the used battery by contacting your local battery recycling programs
Door/window sensor 31AF
  1. Remove your sensor and remove the case by twisting a small flat blade screwdriver in the top case slot (on the flat end of the sensor)
  2. Remove the battery retaining screw
  3. Remove the battery clamp and original batteries from the device
  4. Replace with two new lithium batteries with the “+” side up
    • If you see a white ring around the batteries, you need two CR2032 lithium batteries
    • If you do not see a white ring around the batteries, you need two CR2450 lithium batteries
  5. Replace the battery clamp and retaining screw
  6. Replace the case back onto the sensor
  7. Please dispose of the used battery by contacting your local battery recycling programs
Learn how to replace the battery of your TELUS Secure Business AlarmForce door/window sensor from your phone. Do it yourself by watching the brief video. For more information on managing your TELUS Secure Business, visit
Door/window sensor 36AF
  1. Remove your sensor and use a small flat blade screwdriver or coin in the slot on either end of the transmitter
  2. Slide the original battery out of the device
  3. Replace with a new CR2450 lithium battery
  4. Close the lid back onto the sensor
  5. Please dispose of the used battery by contacting your local battery recycling programs
Glass break detector 91AF
  1. Open your Glass Break Detector sensor case
  2. Remove the battery clip screw and move clip to the side to access the batteries
  3. Install two CR2450 lithium batteries with the “+” side up
  4. Put back the battery clip screw and movie clip to their original location
  5. Close the sensor case
Key fob MKA-315
  1. Use a small Phillips screwdriver to open the back cover of the key fob
  2. Slide out the CR2032 battery and replace with a fresh battery
  3. Secure the back cover by using the two Phillips screws
  4. Please dispose of the used battery by contacting your local battery recycling programs
Key fob RC7
  1. Remove the battery cover of the key fob by using a coin to turn counter-clockwise
  2. Insert a new CR2032 battery into the key fob with the unmarked side (negative) of the battery facing down
  3. Replace the battery cover by securing the cover using a coin to turn clockwise
Wireless motion detector 54AF
  1. Remove the screw at the bottom of the device (if any) and open the case
  2. Replace the original battery in the device by connecting a 9V battery to the battery clip (“+” side up)
  3. Replace the case screw after closing the case
Learn how to replace the battery of your TELUS Secure Business AlarmForce wirless motion detector from your phone. Do it yourself by watching the brief video. For more information on managing your TELUS Secure Business, visit
Wireless motion detector 55AF
  1. Squeeze the top and bottom of the case to open the motion detector
  2. Replace the CR123A battery in the device. Make sure to take note of the battery polarity
  3. Return the sensor to its bracket and snap the case close
Remote keypad KP7
  1. Remove the cover by loosening the screw at the bottom of the device
  2. Replace the 3 AAA batteries within the keypad
  3. Replace the cover and tighten the screws
Learn how to replace the battery of your TELUS Secure Business AlarmForce remote keypad from your phone. Do it yourself by watching the brief video. For more information on managing your TELUS Secure Business, visit
Wireless smoke alarm 72AF
  1. Remove the smoke alarm from mounting plate by twisting it counter clockwise to unlock
  2. Open the cover
  3. Insert the two 9V batteries into the device
  4. Close the cover
  5. Match up the alignment tabs and twist the smoke detector clockwise to lock onto the mounting plate
Wireless smoke alarm 73AF
  2. Open the cover
  3. Insert the CR123 battery into the device
  4. Close the cover
  5. Twist the smoke detector clockwise to lock onto the mounting plate
Wireless keypad 10AF
  1. Remove the top of the case by twisting a small screwdriver between the case halves until it pops open
  2. Remove the original battery from the battery clip
  3. Replace and connect the new 9V battery to the battery clip
  4. Close the case back
Learn how to replace the battery of your TELUS Secure Business AlarmForce wireless keypad from your phone. Do it yourself by watching the brief video. For more information on managing your TELUS Secure Business, visit
Yes
No
Related articles
This Privacy Statement describes how TELUS collects, uses, and discloses your personal information when you use the TELUS Business Connect Mobile App.
