Managing the Battery
Samsung Galaxy A5 (2017) on Android 6.0.1
Copy link
Learn how to manage the battery on your device. Taking care of your battery will extend your battery life.
  1. Step 1/7
  2. Step 2/7
    Tap the Settings icon.
  3. Step 3/7
    Tap Device maintenance.
    The indicator is in the bottom left.
  4. Step 4/7
    Tap Battery.
  5. Step 5/7
    Tap MID.
  6. Step 6/7
    Tap APPLY.
  7. Step 7/7
    Step 7 of 7:
    You've completed the steps!
Was this tutorial helpful?
