X PowerUnderstanding the Device Buttons and Features
You can explore interactive views of your product by selecting a highlighted area on the image or an option from the list. Explore an interactive view of the Home screen and buttons on your device. Learn about various icons, buttons, and features on the front of your device to find where they're located and what they do.
Product Image and Tour Points - Select a tour point overlayed on the product image to learn more about its function
Tour Point selector - Expand a Tour Point to learn more about it and highlight it on the Product Image
Earpiece Speaker
Listen to audio or phone calls from here.
Volume Buttons
Adjusts the volume on your device.
Power/Lock Button
Press to lock or unlock the touchscreen. Hold down to turn the device on or off.
Touchscreen
Used to navigate your device.
Micro SIM Card Slot
Insert or remove your nano SIM card here.
Back Button
Used to go back one screen.
Home Button
Navigates you back to the main Home screen.
Recent Apps Button
Opens a list of the apps you've opened recently and provides access to the Task Manager.
Audio/Headphone Jack
Used to plug in your headset or headphones.
USB/Charging Port
Used to charge your battery and connect your phone to other devices.
Microphone
Built-in microphone used for phone calls and voice commands.
