Using Picture in Picture
Apple iPhone 6S Plus on iOS 15.4.0
Copy link
With the Picture-in-Picture function of your device, you can keep a minimized version of some apps open while you navigate the rest of your device.
  1. Note: Picture in Picture mode allows you to continue watching a video while navigating your device.
  2. Step 1/6
    From a full screen video, press the Home button to access the homescreen.
    Note: For this tutorial we will be using a video that we are watching on YouTube from the Safari app.
  3. Step 2/6
    Drag the video to the desired location.
  4. Step 3/6
    Tap Settings.
    Note: You can access other apps while your video is playing.
  5. Step 4/6
    Tap the video to bring up options.
  6. Step 5/6
    Tap the Full screen icon to go back to full screen mode.
  7. Step 6/6
    Step 6 of 6:
    You've completed the steps!
Was this tutorial helpful?
