Galaxy J3Configuring Location Settings
  2. 2 - Tap the Settings icon.
  3. 3 - Tap Connections.
  4. 4 - Tap Location.
  5. 5 - Switch Location to ON.
    • Note: If you turn Location Services off, you won't be able to use Google Maps or any other apps or features that require your location.
    • Note: You can also choose which apps will have access to your location.
1/6
