G7 ThinQUsing Multi window
You can multitask with two applications on your device by using split screen. This will allow you to have two apps open at once.
Current Step: 1 - From the Home screen, tap the Recent apps icon.
  1. 1 - From the Home screen, tap the Recent apps icon.
  2. 2 - Tap the Maps icon.
  3. 3 - Tap Multi window.
    • Remarque : Not all apps are compatible with Multi window.
  4. 4 - Tap Messages to add it to your Multi window.
  5. 5 - To exit Multi window, drag the Gray bar to the bottom or top of the screen.
1/6
